The PaintBrush (PCX) file format is a bitmap format originally developed by the ZSoft Corporation for the PC Paintbrush program.
To import a PaintBrush file |
1. |
Click File Import.
2. |
Locate the folder in which the file is stored.
3. |
Do one of the following:
(Windows 7 and Windows 8) Choose PCX - PaintBrush (*.pcx) from the list
box next to the File name box.
(Windows XP) Choose PCX - PaintBrush from the Files of type list box.
4. |
Click the filename.
5. |
Click Import.
6. |
Click the drawing page.
To export a PaintBrush file |
1. |
Click File Export.
2. |
Locate the folder in which you want to save the file.
3. |
Choose PCX - PaintBrush from the Save as type list box.
4. |
Type a filename in the File name list box.
5. |
Click Export.
6. |
In the Convert to bitmap dialog box, adjust the width, height, resolution, color
mode, or any of the other settings.
7. |
In the Convert to paletted dialog box, adjust any of the settings.
PaintBrush (PCX) technical notes |
Bitmaps may be black-and-white, 16 colors, grayscale (8-bit), paletted (8-bit), or
RGB color (24-bit).
Run-length encoding (RLE) compression is supported, and the maximum image
size is 64,535 × 64,535 pixels.
These files may contain one, two, or four color planes.
This file format is supported in Corel DESIGNER.
PCX files can be imported if they conform to the following PCX specifications: 2.5,
2.8, and 3.0.
RGB color (24-bit).
RLE compression is supported and the maximum image size is 64,535 × 64,535
pixels.
These files may contain one, two, or four color planes. Files containing three color
planes or more than four color planes cannot be imported.
