By default, PowerTRACE displays both the source bitmap and the traced result. You can also preview a traced result in a single-pane preview window, or you can display a wireframe (outline) view of the traced graphic on top of the source bitmap.
You can zoom in and out to get a better view of the graphic, and you can pan to view areas that fall outside the preview window.
To preview traced results |
In PowerTRACE, choose one of the following options from the Preview list box:
Before and after — displays both the source bitmap and the traced result
Large preview — displays a preview of the traced result in PowerTRACE
Wireframe overlay — displays a wireframe (outline) preview of the traced result
on top of the original bitmap. To control the visibility of the original bitmap
underneath the wireframe, move the Transparency slider.
