You can rotate an object in a drawing by specifying an angle of rotation. You can also specify a point on the drawing around which to rotate, or rotate around a point on the selected object.
| To rotate an object |
1. |
Select an object.
2. |
Click the Shape tools button in the toolbox, and click the Free transform tool
3. |
Click the Free rotation button
If you want to change the reference point to use when rotating the object, locate the Object origin icon
4. |
Type a value in the Angle of rotation box on the property bar.
To specify a point on the drawing to rotate around, type coordinates in the Center of rotation boxes on the property bar. |
You can also rotate a selected object by dragging a rotation handle
You can also rotate an object by typing a value in the Angle of rotation box
on the Transform toolbar. To display the Transform toolbar, click View |
