The roughening effect lets you apply a jagged or spiked edge to objects, including lines, curves, and text. You can control the size, angle, direction, and number of the indentations, whether you use a pen tablet or a mouse.
The roughening effect is determined by the movements of the stylus (or pressure-sensitive pen), by fixed settings, or by automatically applying perpendicular spikes to the line. Tilting the stylus toward and away from the tablet’s surface increases and decreases the size of the spikes. If you are using a mouse, you can specify a tilt angle between 0 and 90°. You can determine the direction of the spikes by changing the angle of rotation (or bearing) of the stylus as you apply the roughening effect to an object. When you are using a mouse, you can set the bearing angle from 0 to 359°. You can also increase or decrease the number of spikes that are applied as you drag.
The roughening effect also responds to the pressure of the stylus on the tablet. The more pressure you apply, the more spikes are created in the roughened area. If you are using a mouse, you can specify values to simulate the stylus pressure.
You can also change the brush nib size.
Roughening allows you to apply jags or spikes to part of an outline or path.
| To roughen an object |
1. |
Select a curve object using the Pick tool
2. |
Click the Shape tools button in the toolbox, and click the Roughen brush tool
3. |
Point to the area on the outline that you want to roughen, and drag the outline to
distort it.
Objects with distortions, envelopes, and perspective applied to them are
converted to curve objects before the roughening effect is applied.
To make the tilt angle and bearing responsive to the stylus, right-click the
roughened object with the Roughen brush tool, and select a command from
the context menu.
To see the minimum and maximum values for the roughening controls, right-
click the control on the property bar, and click Settings.
