By default, drawings are saved to the Corel DESIGNER file format (DES). You can save a drawing to other vector file formats as well. If you want to use a drawing in another application, you must save it to a file format that is supported by that application. For information about saving files to other formats, see Exporting files.
When you save a drawing, Corel DESIGNER lets you add reference information so that you can easily find and organize drawings later on. On Windows 7 and Windows 8, you can attach tags (also known as properties) such as title, subject, and rating. On Windows XP, you can assign notes and keywords to a drawing.
You can also save selected objects in a drawing. For large drawings, saving only the selected objects reduces the file size, which can decrease the time it takes to load the drawing.
When saving a file, you can use advanced options to control how bitmaps, textures, and vector effects, such as blends and extrusions, are saved with the drawing.
You can also save a drawing as a template, which lets you create other drawings with the same properties. For information about saving a drawing as a template, see Working with templates.
| To save a drawing |
1. |
Click File |
2. |
Type a filename in the File name box.
3. |
Locate the folder where you want to save the file.
If you want to save the drawing to a vector file format other than DES - Corel DESIGNER, choose a file format from the Save as type list box. |
If you are using an expired trial version of Corel DESIGNER, you will not be
able to save drawings.
Saving a drawing to a previous version of Corel DESIGNER may result in loss
of certain effects that were not available in the previous version of the
application.
You can also save a drawing by clicking File |
You can also save a drawing by clicking the Save button
| To use advanced options when saving |
1. |
Click File |
2. |
Click Advanced.
3. |
Enable any of the following check boxes:
Save presentation exchange (CMX) — saves a drawing as a Corel
Presentations Exchange (CMX) file so that you can open and edit it in other
Corel applications, such as WordPerfect
Use bitmap compression — reduces the file size by compressing bitmap
effects, such as bitmap extrusions, transparencies, and drop shadows
Use graphic object compression — reduces the file size by compressing vector
objects, such as polygons, rectangles, ellipses, and perfect shapes
Using compression increases the time required for opening and saving a drawing. |
4. |
If a drawing contains texture fills, enable one of the following options:
Save textures with the file — saves custom texture fills with the file
Rebuild textures when opening the file — re-creates texture fills when you
open the saved drawing
5. |
If a drawing contains blends and extrusions, enable one of the following options:
Save blends and extrudes with the file — saves all blends and extrusions
included in a drawing
Rebuild blends and extrudes when opening the file — re-creates blends and
extrusions when you open the saved drawing
Choosing to save textures, blends, and extrusions with the file increases the file
size but lets you open and save a drawing more quickly. Conversely, choosing
to rebuild textures, blends, and extrusions when a saved drawing is opened
decreases the file size but increases the time required for saving or opening a
drawing.
| To save a drawing that is compatible with an older version of Corel DESIGNER |
1. |
Click File |
2. |
3. |
4. |
Choose a version from the Version list box.
5. |
Click Save.
If the drawing includes text, enable one of the following options from the Save to a previous version dialog box: |
Keep text appearance — converts text to curves so it displays correctly when
opened in a previous version of Corel DESIGNER. However, the text is no longer
editable.
Keep text editable — preserves text so it remains editable. However, this
option may change the appearance and flow of text when opened in a previous
