You must select a table, table rows, table columns, or table cells before you insert rows or columns, change the table border properties, add a background fill color, or edit other table properties. You can move selected rows and columns to a new location in a table. You can also copy or cut a row or column from one table and paste it in another table. In addition, you can move from one table cell to another when editing the table cell text, and you can set the direction in which the Tab key lets you move around a table.
| To select a table, row, or column |
1. |
Click the Table tool
2. |
Perform one of the following tasks.
| To select table cells |
You can also select a cell by inserting the Table tool pointer in an empty cell
and pressing Ctrl + A.
You can also use the Shape tool
| To move a table row or column |
1. |
Select the row or column that you want to move.
2. |
Drag the row or column to another location in the table.
| To move a table row to another table |
1. |
Select the table row that you want to move.
2. |
Click Edit |
3. |
Select a row in the other table.
4. |
Click Edit |
5. |
Choose one of the following options:
Replace selected row
Insert above selected row
Insert below selected row
| To move a table column to another table |
1. |
Select the table column that you want to move.
2. |
Click Edit |
3. |
Select a column in the other table.
4. |
Click Edit |
5. |
Replace selected column
Insert left of the selected column
Insert right of the selected column
| To move to the next table cell |
With the Table tool inserted in a cell, press Tab.
If you are pressing Tab in a table for the first time, you must choose a tab order option from the Tab order list box. |
You can use the Tab key to move to the next cell only if the Move to the next
cell option is enabled in the Tab key options dialog box.
| To change the navigational direction of the Tab key |
1. |
Click Tools |
2. |
In the Workspace, Toolbox list of categories, click Table tool.
3. |
Enable the Move to the next cell option.
4. |
From the Tab order list box, choose one of the following options:
Left to right, top to bottom
Right to left, top to bottom
You can program the Tab key to insert a tab character in the table text by
enabling the Insert a tab character into the text option.
