All objects that you create are based on the default property values, which include outline style and fill color. You can change the properties for a selected object, but the default property values are applied automatically when you draw a new object.
There are several ways to change the default property values.
To change the default property values |
You can also click Tools Save settings as default to save the current
settings, or you can access the Options dialog box to set specific settings. See
Saving defaults for more information.
