You can enable any of the following tracing options.
Quick Trace method — You can change the default Quick Trace settings to any
preset style, or to the most recently used settings.
Performance — This option determines how source bitmaps between 1 and 5
megapixels in size are handled, and how the quality of the traced results is affected.
The performance of PowerTRACE depends on the size and color depth of the
source bitmaps as well as on the available system memory. High-quality traced
results require high-quality source bitmaps, which are often quite large. The larger
the source bitmap, the more resources are required. Bitmaps that are too large need
to be downsampled before tracing, which may decrease the image quality. To trace
large bitmaps without sacrificing quality, you can set PowerTRACE to trace images
as large as 5 megapixels (provided RAM is sufficient). To achieve maximum
performance, you can set PowerTRACE to prompt you to downsample bitmaps
larger that 1 megapixel.
Merge colors — You can choose whether to merge colors in a traced result by
averaging their values or by replacing the colors to be merged with the first color
you select.
| To set default tracing options |
1. |
Click Tools |
2. |
In the Workspace list of categories, click PowerTRACE.
3. |
Perform any of the following tasks.
You can also access the PowerTRACE page in the Options dialog box by
clicking Options in PowerTRACE.
