Reflect Nodes mode lets you edit nodes and have the same edits take place in reverse on corresponding nodes. For example, you can move a node to the right and have its corresponding node move the same distance to the left.
This is useful when you want to shape curve objects and have the changes mirrored across their left and right or top and bottom.
Usually, you will start with one curve object that is more or less symmetrical, or two curve objects, where the second was created by mirroring the first.
To shape a curve object by using Reflect Nodes mode |
1. |
Click the Shape tool
2. |
Select corresponding nodes on the left and right or top and bottom.
To select multiple nodes, drag to select the nodes, or click a node, hold down Shift, and click each additional node. |
3. |
On the property bar, click one of the following buttons:
Reflect nodes vertically
Reflect nodes horizontally
4. |
Edit the nodes on one side.
The changes occur in reverse on corresponding nodes on the other side. |
To shape multiple objects by using Reflect Nodes mode, click the first object,
and drag to select nodes; or hold down Shift, and click each node on the first
object. Then hold down Shift, click the second object, and drag to select nodes,
or hold down Shift and click each node on the second object.
