Corel DESIGNER lets you size and scale objects. In both cases, you can change the dimensions of an object proportionally by preserving its aspect ratio. You can size an object by specifying values or changing the object interactively. Scaling changes an object’s dimensions by a specified percentage.
Objects are sized or scaled from the object’s origin. You can change an object’s origin from its center to any one of its eight selection handles.
You can also specify a rectangular area for selected objects to scale into.
| To specify the size of an object |
1. |
Select an object.
2. |
Click View |
3. |
Type values in the Object size boxes on the Transform toolbar.
| To size an object interactively |
You can set a precise size for the object by clicking the Geometric properties
button
| To scale an object |
1. |
Select an object.
2. |
Click the Shape tools button in the toolbox, and click the Free transform tool
3. |
Click the Free scale button
If you want to change the reference point to use when scaling the object, locate the Object origin icon
4. |
On the property bar, type values in the Scale factor boxes to specify a percentage
by which to scale the object horizontally or vertically.
If you want to maintain the aspect ratio, click the Lock ratio button
You can also scale an object by dragging a selection handle.
You can also scale an object by typing values in the Scale factor boxes on the
Transform toolbar. To display the Transform toolbar, click View |
