You can crop, split, and erase portions of objects.
Cropping lets you quickly remove unwanted areas in objects and imported graphics, eliminating the need to ungroup objects, break linked groups apart, or convert objects to curves. You can crop vector objects and bitmaps.
Cropping objects
When cropping objects, you define a rectangular area (cropping area) that you want to keep. Object portions outside the cropping area are removed. You can specify the exact position and size of the cropping area, and you can rotate and resize it. You can also remove the cropping area.
You can crop only selected objects without affecting other objects in a drawing, or you can crop all objects on the drawing page. In either case, the affected text and shape objects are automatically converted to curves.
You can split a bitmap or vector object in two and reshape it by redrawing its path. You can split a closed object along a straight or jagged line. Corel DESIGNER lets you choose between splitting an object into two objects, or leaving it as one object composed of two or more subpaths. You can specify whether you want to close the paths automatically or keep them open.
The Knife tool creates two separate objects by cutting the ellipse in half. The two objects are separated and used to form the top of the screw.
You can erase unwanted portions of bitmaps and vector objects. Erasing automatically closes any affected paths and converts the object to curves. If you erase connecting lines, you create subpaths rather than individual objects. You can also delete portions of objects, called virtual line segments, that are between intersections. For example, you can delete loops from a curved line, or you can delete interior lines from overlapping shapes.
| To crop objects |
1. |
Select the objects that you want to crop.
If no objects on the drawing page are selected, all objects will be cropped. |
2. |
In the toolbox, click the Deletion tools button, and click the Crop tool
3. |
Drag to define a cropping area.
4. |
Double-click inside the cropping area.
Objects on locked, hidden, Grid, or Guides layers cannot be cropped. Also, you
cannot crop OLE and Internet objects, rollovers, or the content of PowerClip
objects.
During cropping, affected linked groups, such as contours, blends, and
extrusions, are automatically broken apart.
You can move, rotate, and size the cropping area interactively as you would any
object. To move the cropping area, drag it to a new position. To size the
cropping area, drag any of its handles
You can remove the cropping area by pressing Esc.
| To split an object |
1. |
Click the Deletion tools button, and click the Knife tool
2. |
Position the Knife tool over the object’s outline where you want to start cutting.
The Knife tool snaps upright when positioned properly. |
3. |
Click the outline to start cutting.
4. |
Position the Knife tool where you want to stop cutting, and click again.
By default, objects are split into two objects and paths are automatically closed.
When you use the Knife tool on a selected object, the object becomes a curve
object.
| To divide an object into equal segments |
1. |
Select the object that you want to divide.
2. |
Click Arrange |
3. |
In the Shaping docker, specify the following:
Divisions — number of segments to divide the object into
Gap — amount of space between segments
If you want to group the segments after the divide, enable the Group divisions check box. |
If you want the segments to be combined as one object, enable the Combine divisions check box. Disable the check box if you want the segments to be individual objects. |
If you do not want to delete the original object, disable the Delete selected object check box. |
4. |
Click Apply.
This feature creates a copy of the object and applies the divisions to the new
object. If you do not delete the original object, you will have two objects one
on top of the other, and the object will appear unchanged.
The resulting object inherits the original object’s edge and fill properties.
You can divide curves, arcs, rectangles, and polygons. To divide other objects,
you must first convert them to curves. You cannot divide images.
You can select multiple objects to divide at one time. If you also enable the
Group divisions check box, all the objects that you divide are grouped into a
single group.
| To break a path |
| To erase portions of an object |
1. |
Select an object.
2. |
Click the Deletion tools button, and click the Eraser tool
3. |
Drag over the object.
When you erase portions of objects, any affected paths are automatically
closed.
You can erase in straight lines by clicking where you want to start erasing, and
then clicking where you want to finish erasing. Hold down Ctrl if you want to
constrain the line’s angle.
You can also erase an area of a selected object by double-clicking the area with
the Eraser tool.
| To delete a virtual line segment |
1. |
Click the Deletion tools button, and click the Virtual segment delete tool
2. |
Move the pointer to the line segment that you want to delete.
The Virtual segment delete tool snaps upright when positioned properly. |
3. |
Click the line segment.
The Virtual segment delete tool does not work on linked groups (like drop
shadows), text, or images.
