The TARGA (TGA) graphics format is used for saving bitmaps. It supports various compression systems and can represent bitmaps ranging from black-and-white to RGB color. You can import or export TGA files in Corel DESIGNER.
To export a TARGA file |
1. |
Click File Export.
2. |
Locate the folder in which you want to save the file.
3. |
Choose TGA - Targa bitmap from the Save as type list box.
4. |
Type a filename in the File name list box.
To compress an image while exporting it, choose a compression type from the Compression type list box. |
5. |
Click Export.
6. |
In the Convert to bitmap dialog box, adjust the width, height, resolution, color
mode, or any of the other settings, and click OK.
7. |
In the TGA export dialog box, enable one of the following options:
Normal
Enhanced
Black-and-white images cannot be saved as TARGA files.
TARGA (TGA) technical notes |
The following features are supported: uncompressed color-mapped images,
uncompressed RGB images, run-length encoding (RLE) compressed color-mapped
images, RLE-compressed RGB images (types 1, 2, 9, and 10 as defined by the
AT&T Electronic Photography and Imaging Center), and masks.
The type of file produced depends on the number of colors exported. For example,
24-bit color TARGA (TGA) files are exported as RLE-compressed RGB bitmaps.
You can import TGA files from 8-bit grayscale to 24-bit RGB.
Masks are not saved in 1-bit black-and-white or 8-bit paletted files.
RLE compression is supported, and the maximum image size is 64,535 × 64,535
pixels.
