The Tagged Image File format (TIFF) is a raster format designed as a standard. Almost every graphics application can read and write TIFF files. TIFF supports various color modes and bit depths.
For information about importing TIFF files, see To import a file into an active drawing.
To export a TIFF file |
1. |
Click File Export.
2. |
Locate the folder in which you want to save the file.
3. |
Choose TIF - TIFF bitmap from the Save as type list box.
4. |
Type a filename in the File name list box.
5. |
Click Export.
6. |
In the Convert to bitmap dialog box, adjust the width, height, resolution, color
mode, or any of the other settings, and click OK.
TIFF technical notes |
When importing a TIFF that contains multiple pages, you can import all pages or
choose the individual pages that you want to import.
Black-and-white, color, and grayscale TIFF files up to and including the 6.0
specification can be imported and exported.
TIFF files compressed using JPEG, ZIP, CCITT, Packbits 32773, or LZW
compression can also be imported. However, you may notice additional loading
time with these files because the program decodes the file compression.
