You can transform the color and tone of an image to produce a special effect. For example, you can create an image that looks like a photographic negative or flatten the appearance of an image. To transform the color and tone of images, you can use the following effects:
Deinterlace — lets you remove lines from scanned or interlaced images
Invert — lets you reverse the colors of an image. Inverting an image creates the
appearance of a photographic negative.
Posterize — lets you reduce the number of tonal values in an image. Posterize
removes gradations and creates larger areas of flat color.
To transform color and tone |
1. |
Select a bitmap.
2. |
Click Effects Transform, and click any of the following:
Deinterlace
Invert
Posterize
