You can align objects interactively on the drawing page by using alignment guides. Alignment guides are temporary guidelines that appear when you create, resize, or move objects in relation to nearby objects. While dynamic guides provide precise measurements for creating technical illustrations, alignment guides are useful in page layout to align text or graphic elements quickly and accurately.
Alignment guides appear as an object is moved.
Alignment guides help you align the centers and edges of objects. If you want to align an object at a set distance from the edge of another object, you can set margins for the alignment guides. You can display the margin alignment guides in addition to other alignment guides, or disable all other alignment guides and show only the margin alignment guides.
Margin alignment guides let you use offset margins, inset margins, or both. There are separate controls for horizontal and vertical margin alignment guides, so you can modify settings for one without affecting the other.
You can offset (left) and inset (right) margin alignment guides.
Alignment guides are turned off by default. You can easily enable or disable alignment guides, or modify their default settings, including the color and line style. You can choose whether alignment guides appear for individual objects in a group, or for the bounding box of the group as a whole.
The Intelligent Spacing feature lets you precisely arrange and position an object in relation to other onscreen objects, and the Intelligent Dimensioning feature lets you intuitively scale and rotate an object in relation to other onscreen objects.
Intelligent Dimensioning displays indicators when an object is rotated to the same angle (top) or scaled to same size (bottom) as the closest object.
Intelligent Spacing displays indicators when an object is equidistant from two other objects (left) or has the same spacing as the closest onscreen objects (right).
| To enable or disable alignment guides |
1. |
Click Tools |
2. |
In the Alignment and dynamic guides docker, click the Alignment guides
button
3. |
Enable or disable the check box in the upper-right corner of the Alignment guides
section.
You can also enable or disable alignment guides by clicking the Alignment
guides button on the Layout toolbar. To open the Layout toolbar, click
Layout |
You can also enable alignment guides by pressing Shift + Alt + A.
| To modify alignment guide settings |
1. |
Click Tools |
2. |
button
3. |
Perform any of the following tasks.
You can access some alignment guide controls on the Layout toolbar by
clicking the Layout toolbar button
| To add margin alignment guides |
1. |
Click Tools |
2. |
button
3. |
