If you want to view or edit a file before you incorporate it into your project, you can open it in CorelDRAW, Corel DESIGNER, Corel PHOTO-PAINT, or its associated application.
You can insert and place content in your document. Images that are obtained from online sources, such as iStockphoto and Fotolia, may be subject to copyright and usage restrictions. Such images, also referred to as “comp images,” are often low-resolution or watermarked. To use comp images, you must first check with the owner if you have rights to use them and purchase them if necessary. Then, you can replace the comp images in your document with the purchased images. You can also view a list of all comp images in a document.
In addition, in Corel CONNECT, you can perform many tasks (such as renaming, printing, compressing, emailing, and faxing files) that are available through the Windows operating system. Right-click a file in the viewing pane, and choose a command.
| To open a file |
Select a thumbnail, and choose an action from the following table.
You can also open a file by right-clicking it and choosing the option that you
want.
You can also open multiple selected files.
| To insert a file into an active document |
To
Do the following
Insert a file into an active document by using the Corel CONNECT utility
Drag a file from the Tray or viewing pane to the active document.
Insert a file into an active document by using the Connect docker
Do one of the following:
Insert a file into an active document by using the Tray docker
Select the file, and click one of the following buttons in the Tray docker:
Note that the Import buttons are not available in the standalone utility.
Insert and place a vector graphic in a document
Click the Import or Import and link button and do one of the following:
You can also insert a file into an active document by dragging the file from the
viewing pane or the Tray docker to the active document.
You can also insert a file into an active document by right-clicking the file in
the viewing pane and choosing an import command.
You can also insert multiple selected files.
| To check, purchase, and replace a comp image |
1. |
In your document, right-click a comp image, and click Open comp source.
2. |
On the Web site of the online content provider, check the copyright and usage
restrictions for the image, and purchase it if necessary.
3. |
In your document, right-click a comp image, and click Replace comp.
4. |
Navigate to the purchased image, and click Import.
Transformations, such as scaling, rotating, and resizing, that were applied to
the comp image are preserved in the final image.
| To view a list of all comp images in a document |
Open a document, and do one of the following:
Click File |
Click File |
When you export a document to the Adobe Illustrator (AI), Scalable Vector
Graphics (SVG), HTML, or PDF file format, you can view a list of all comp
images in the preflight summaries.
