You can specify a projected drawing mode by choosing drawing profiles and drawing planes from the Drawing plane toolbar. However, you can have only one drawing profile and one drawing plane active at a time.
You can draw an object in a projected drawing mode, or you can project an object onto a drawing plane. You can also unproject an object from a drawing plane; this reconstructs the object as it would appear in an orthographic view.
To display or hide the Drawing Plane toolbar |
Click View Toolbars Drawing plane.
A check mark beside the Drawing plane command indicates that the Drawing plane toolbar is displayed. |
To choose a preset drawing profile |
From the Drawing profiles list box on the Drawing plane toolbar, choose one of
the following preset drawing profiles:
Cabinet oblique (0, 90, 60)
Cavalier oblique (0,90,45)
Dimetric (37,90,37)
Dimetric (16,90,37)
Dimetric (7,90,42)
Dimetric (15,90,15)
Isometric (30,90,30)
Trimetric (12,90,23)
Trimetric (5,90,30)
Trimetric (45,90,7)
Trimetric (54,90,17)
To choose a drawing plane |
On the Drawing plane toolbar, choose one of the following drawing planes:
Orthographic
Top
Front
Right
To draw an object in a projected drawing mode |
1. |
From the Drawing profiles list box on the Drawing plane toolbar, choose a
drawing profile.
2. |
On the Drawing plane toolbar, choose the Top, Front, or Right drawing plane.
3. |
Draw an object.
To project an object onto a drawing plane |
1. |
Select an object.
2. |
Click Arrange Transformations Project.
3. |
In the Transformations docker, choose Project from the list box.
4. |
In the Plane area, click one of the following buttons:
Top — projects the object onto the top plane
Front — projects the object onto the front plane
Right — projects the object onto the right plane
5. |
To specify an origin point on the drawing around which to project the selected
object, do one of the following:
Type values in the X and Y boxes to specify coordinates along the horizontal and
vertical axes.
Click the Specify point button
next to the X and Y boxes, and click a point
on the drawing.
Enable the Relative origin check box, and click the point on the origin locator
that corresponds to the point on the object from which you want to project
the object.
If you want to leave the original object unchanged and apply the transformation to a copy, type 1 in the Copies box. The number of copies cannot exceed one. |
6. |
Click Apply.
Applying a contour to a projected object may not produce the desired results.
It is recommended that you apply a contour to the object in its unprojected
state and then project the object. Contour groups can be unlinked by clicking
Arrange Break contour group apart.
To unproject an object from a drawing plane |
1. |
Select an object.
2. |
3. |
In the Transformations docker, choose Unproject from the list box.
4. |
Top — unprojects the object from the top plane
Front — unprojects the object from the front plane
Right — unprojects the object from the right plane
5. |
To specify an origin point in the drawing around which to unproject the selected
vertical axes.
on the drawing.
that corresponds to the point on the object from which you want to unproject
the object.
6. |
Click Apply.
