Rule classes contain groups of grammar and style rules. Grammatik uses rule classes to detect common writing errors.
You can enable or disable rules at any time during a Grammatik session. When you disable a rule, Grammatik ignores all the errors associated with that rule during the current proofreading session. You can also choose which rule classes to apply during a Grammatik session or save a new set of rules as a checking style.
To enable a rule |
1. |
Click Text Writing tools Grammatik.
2. |
Click Options Turn on rules.
3. |
In the Turn on rules dialog box, choose the rules you want to enable from the
Rules list.
The Turn on rules command is available only when you have disabled a rule
during proofreading. Otherwise, it is grayed.
To disable a rule |
1. |
2. |
Start a new grammar-checking session.
3. |
When Grammatik alerts you to an error that you do not want to flag, click Turn
off.
To add rule classes |
1. |
2. |
Click Options Checking styles.
3. |
In the Checking styles dialog box, choose a checking style from the list.
4. |
Click Edit.
5. |
In the Edit checking styles dialog box, enable any check boxes beside the rule
classes in the Rule classes list that you want to add.
To save a set of rules as a new checking style |
1. |
2. |
Click Options Save rules.
3. |
In the Save rules dialog box, click Save as.
4. |
In the Save as checking style dialog box, type a name in the Custom style name
box.
The Save rules command is available only when a rule has been turned off.
