When you start a document from a template by using the File
New from template command, Corel DESIGNER formats the page according to the page layout settings in the template and then loads all objects and template’s styles into the new document. With this method, you can search and browse for templates.
If you want to use only the styles from a template, you can create a blank document by using the File
Open command.
You can also import styles from a template into a document at any time.
| To start a document from a template |
1. |
Click File |
2. |
Search or browse for templates.
3. |
Choose a template from the Templates list.
4. |
Click Open.
For information about searching for templates, see To search for templates.
You can also start a document from a template by clicking File |
| To import styles from a template into a document |
1. |
Click Window |
2. |
In the Object styles docker, open the Import, export, or save defaults flyout,
and then click the Import style sheet button
3. |
Locate the folder where the template is stored.
4. |
Click the template that contains the styles that you want to load.
5. |
Click Open.
Only the template styles are imported. Page layout settings and objects saved
with the template are ignored. The attributes of existing objects are
maintained.
