You can display rulers in the drawing window to help you draw, size, and align objects precisely. You can hide the rulers or move them to another position in the drawing window. You can also customize the ruler settings to suit your needs. For example, you can set the ruler origin, choose a unit of measure, and specify how many marks or ticks appear within each full unit mark.
By default, Corel DESIGNER applies the units used for the rulers to the duplicate and nudge distances. You can change the default and specify different units for these and other settings. For information about nudging, see Moving objects.
| To hide or display the rulers |
Click View |
A check mark beside the Rulers command indicates that the rulers are displayed. |
| To move a ruler |
Hold down Shift, and drag a ruler to a new position in the drawing window.
| To customize ruler settings |
1. |
Click Tools |
2. |
In the Document list of categories, click Rulers.
3. |
In the Units area, choose a unit of measure from the Horizontal list box.
If you want to use a different unit of measure for the vertical ruler, disable the Same units for horizontal and vertical rulers check box, and choose a unit of measure from the Vertical list box. |
4. |
In the Origin area, type values in the following boxes:
Horizontal
Vertical
5. |
Type a value in the Tick divisions box.
If you change the unit of measure for rulers, the unit of measure for nudge
distances automatically changes as well, unless you first disable the Same units
for duplicate distance, nudge and rulers check box in the Nudge area.
You can access ruler settings directly by double-clicking a ruler.
You can specify nudge settings by typing values in the Nudge, Super nudge,
and Micro nudge boxes in the Nudge area.
