The writing tools let you check your text in many ways. By using the spelling checker and Grammatik, you can check the spelling and grammar in an entire drawing, part of a drawing, or only selected text.
You can manually edit text and then resume checking the drawing.
The spelling checker and Grammatik replace words or phrases in two ways: you can choose a word, or define an automatic replacement for a word. Defining automatic replacement words is useful for words that are regularly misspelled. Automatic replacement words are stored in a user word-list file. For more information about user word-list files, see Using word lists.
You can skip a writing error once but flag subsequent occurrences of the problem, or you can skip the error throughout the entire proofreading session.
To check the spelling or grammar in an entire drawing | ![]() |
1. |
Click Text ![]() |
Spell check
Grammatik
2. |
Choose Document from the Check list box.
3. |
Click Start.
To check the spelling or grammar in part of a drawing | ![]() |
1. |
Click Text ![]() |
Spell check
Grammatik
2. |
From the Check list box, choose one of the following:
Paragraph
Selected text
Sentence
Word
3. |
Click one of the following:
Start — begins a new check
Resume — continues an interrupted check
The options available from the Check list box vary according to the type of
drawing that you are checking.
To check the spelling or grammar of selected text | ![]() |
1. |
Select the text you want to check.
2. |
Click Text ![]() |
Spell check
Grammatik
By default, the Auto start command is enabled for the spelling checker and Grammatik. If you want to disable the Auto start command, click Options ![]() |
To edit text manually | ![]() |
1. |
Click Text ![]() |
Spell check
Grammatik
2. |
When the spelling or grammar checker stops on a word or phrase, click where you
want to make changes.
3. |
Edit the text.
To replace a word or phrase | ![]() |
1. |
Click Text ![]() |
Spell check
Grammatik
2. |
When the spelling or grammar checker stops, choose a word or phrase from the
Replacements list.
3. |
Click Replace.
If the spelling checker does not offer replacement words, you can edit text
manually in the Replace with box.
To define automatic text replacements | ![]() |
1. |
Click Text ![]() |
Spell check
Grammatik
2. |
When the spelling or grammar checker stops on a word, click Auto replace.
To skip a spelling or grammar error once | ![]() |
1. |
Click Text ![]() |
Spell check
Grammatik
2. |
When the spelling or grammar checker stops, click Skip once.
To skip all occurrences of an error | ![]() |
1. |
Click Text ![]() |
Spell check
Grammatik
2. |
When the spelling or grammar checker stops, click Skip all.
You can also skip all occurrences of a word for all proofreading sessions by
adding it to a user word list. For more information about user word-list files,
