You can use the thesaurus to refine your writing style. The thesaurus lets you look up options such as synonyms, antonyms, and related words.
You can replace a word by using the thesaurus. When you look up a word, the thesaurus provides a short definition and a list of the lookup options selected. The thesaurus also maintains a history list of the words that you have looked up. Each time you start the thesaurus, it begins a new history list.
The thesaurus automatically replaces a word with a suggested word, but you can also use the thesaurus to insert words.
| To replace a word |
1. |
Select a word.
2. |
Click Text |
3. |
Click Look up.
4. |
In the list of categories, double-click a definition and click a word.
5. |
Click Replace.
In some instances, you are prompted to select the correct form of the word that
you want to insert. This prompt appears when the word that you want to
replace is spelled the same in both the present and past tenses (for example,
“read”), or when the word can be used as more than one part of speech (for
example, “wonder,” which can be used as either a noun or a verb).
Click the left and right arrows to scroll through word lists.
| To insert a word |
1. |
In the drawing, click where you want to insert the word.
2. |
Click Text |
3. |
Type a word in the box at the top of the Thesaurus page.
4. |
Click Look up.
5. |
Choose a word from the list box.
6. |
Click Insert.
