The Windows bitmap (BMP) file format was developed as a standard for representing graphic images as bitmaps on the Windows operating system.
| To import a bitmap file |
1. |
Click File |
2. |
Locate the folder in which the file is stored.
3. |
Do one of the following:
(Windows 7 and Windows 8) Choose BMP - Windows bitmap (*.bmp; *.dib;
*.rle) from the list box next to the File name box.
(Windows XP) Choose BMP - Windows bitmap from the Files of type list box.
4. |
Click the filename.
5. |
Click Import.
6. |
Click the drawing page.
| To export a bitmap file |
1. |
Click File |
2. |
Locate the folder in which you want to save the file.
3. |
Choose BMP - Windows bitmap from the Save as type list box.
4. |
Type a filename in the File name list box.
5. |
Click Export.
6. |
In the Convert to bitmap dialog box, adjust the width, height, resolution, color
mode, or any of the other settings.
| Windows Bitmap (BMP) technical notes |
You can import Windows Bitmap files conforming to the Windows and OS/2 BMP
specifications.
Windows Bitmap files may be black-and-white, 16 colors, grayscale, paletted, or
RGB color (24-bit), and print accordingly, depending on your printer.
Run-length encoding (RLE) compression may be used on all bitmaps, except RGB
color (24-bit), and black-and-white bitmaps.
The resolution ranges from 72 to 300 dpi, or higher if you choose custom settings.
The maximum image size is 64,535 × 64,535 pixels.
Because raster images such as bitmaps are mapped pixel by pixel to the page, the
resolution does not increase. Instead, your bitmap appears jagged, with an
apparent loss of resolution.
