If a document contains text and was created in a previous version of Corel DESIGNER, such as Corel DESIGNER X5, you must update the legacy text before you can use new text features such as OpenType options and aligning text with the baseline grid. For more information, see Working with OpenType features and Aligning text by using the baseline grid.
| To update legacy text |
1. |
Open the document with legacy text.
An Update toolbar appears at the top of the drawing window. |
2. |
Click Update.
To undo the update, click Undo on the Update toolbar. However, once you make changes to the updated text, this option is no longer available. |
When legacy text is updated, its flow and layout may change.
You can also update legacy text by clicking the Update button in the
Character area of the Property manager docker.
