You can save time by using a macro to automate a series of repetitive tasks. A macro lets you specify a sequence of actions so that you can quickly repeat those actions later.
You don’t need any programming experience to use macros — in fact, the basic tools for working with macros are available within the main application window. However, if you want to have more control over your macros, you can use the following built-in programming environments:
Microsoft Visual Basic for Applications (VBA) — a subset of the Microsoft Visual
Basic (VB) programming environment, and an excellent choice for beginners. You
can use VBA to create basic macros for personal use, but you can also use it to
create more advanced macro projects.
Microsoft Visual Studio Tools for Applications (VSTA) — the successor to VBA,
and an excellent choice for developers and other programming experts. VSTA
provides the tools and features that you need to create the most advanced kinds of
macro projects.
For detailed information on the differences between VBA and VSTA, please see
the Corel DESIGNER Macros Help file (des_om.chm, which is located in the
Data folder for the installed software).
The macro features for VBA and VSTA are installed with the software by default, but you can manually install these features if necessary. You can specify options for the VBA feature.
The macro features provide several tools for working with macros in the main application window:
Macros toolbar — provides easy access to common macro functions
Macro Manager docker — provides easy access to all available macro projects for
VBA, and to basic functions for working with those projects
Macro Editor (formerly the Visual Basic Editor) — provides advanced functions for
creating VBA-based macro projects
VSTA Editor — provides advanced functions for creating VSTA-based macro
projects
Macros are stored in modules (also called “code modules”), which are stored in macro projects. The Macro Manager docker lets you view and manage all of the macro projects, modules, and macros that are available to you.
You can use the Macro Manager docker to create macro projects in the form of Global Macro Storage (GMS) files. Using a GMS file is an excellent way to bundle the components of your macro project for sharing with others. You can use the Macro Manager docker to open (or “load”) the macro projects that you create, as well as the macro projects that install with the software or that are otherwise made available to you. You can also use the Macro Manager docker to rename macro projects, as well as to copy and close (or “unload”) GMS-based macro projects.
Some macro projects are locked and cannot be modified.
When you create a document, a macro project for that document is
automatically added to the Macro Manager docker. Although you can store
macros within the macro project for a document — for example, to create an
all-in-one template — it is recommended that you instead use GMS files to
store your macro projects.
Each macro project contains at least one module. You can use the Macro Manager docker to add a module to a VBA-based macro project, or to open existing VBA modules for editing. You can also use the Macro Manager docker to rename or delete VBA modules.
The editing feature is disabled for some modules.
Finally, you can use the Macro Manager docker to create macros within the available modules. You don’t need any programming experience to create macros; however, if you have programming experience and want to edit VBA macros, you can do so by using the Macro Editor. You can also use the Macro Manager docker to rename and delete VBA macros.
Corel DESIGNER includes sample macros, which supply additional
functionality, demonstrate automation in the software, and provide sample
code. For information on these sample macros, please see the
You can record macros and save them for later use.
You can also record temporary macros for actions that you need to repeat only a few times. A temporary macro is accessible until a new temporary macro is recorded.
The recording feature is disabled for some macro projects.
Before recording a macro, make sure that you know exactly which actions you
want to record and the order in which you want to record them. When you
start recording, the macro recorder captures every change that you make in a
drawing. For example, if you create a shape, resize the shape, and then change
its color, the macro records all the changes. When you are done making the
changes, you must stop recording the macro.
You can perform the actions that are associated with a macro by playing that macro.
You can also play a temporary macro.
Corel DESIGNER provides additional resources that contain helpful information about macros. These additional resources, which are located in the Data folder for the installed software, are described in the following table.
The Macros Help file includes documentation on every feature and function that can be automated in the application. (Collectively, these features and functions are called an “object model.”) You can easily access the Macros Help file from within the Macro Editor.
For more detailed information about VBA and its programming environment,
please consult the Microsoft Visual Basic Help from the Help menu in the
Macro Editor.
For more detailed information about VSTA and its programming
environment, please consult the Help menu in the VSTA Editor.
| To manually install the macro features |
1. |
Insert the installation disc into your computer.
If the installation wizard does not start automatically, locate and run the Setup.exe file on the installation disc. |
2. |
Follow the on-screen instructions for modifying the software.
3. |
On the Features page of the setup, enable the following check boxes in the
Utilities list box:
default.
| To specify VBA options |
1. |
Click Tools |
2. |
In the Workspace list of categories, click VBA.
3. |
In the Security area, specify how to control the risk of running malicious macros by
clicking Security options.
If you want to bypass this security feature, enable the Trust all installed GMS modules check box, and then proceed to step 6. |
4. |
On the Security level page of the Security dialog box, enable one of the following
options:
Very high — allows only macros installed in trusted locations to run. All other
signed and unsigned macros are disabled.
High — allows only signed macros from trusted sources to run. Unsigned
macros are automatically disabled.
Medium — lets you choose which macros run, even if they are potentially
harmful
Low (not recommended) — allows all potentially unsafe macros to run. Enable
this setting if you have virus-scanning software installed, or if you check the
safety of all documents that you open.
5. |
On the Trusted publishers page of the Security dialog box, review which macro
publishers are trusted. Click View to display details on the selected macro
publisher, or click Remove to delete the selected macro publisher from the list.
If desired, you can enable or disable the Trust access to Visual Basic project check box for the selected macro publisher. |
6. |
Disable the Delay load VBA check box if you want to load the VBA feature at
start-up.
| To access the macro tools |
| To create a macro project |
In the Macro Manager docker, do one of the following:
Click Visual Basic for Applications in the list, click New, and then click New
macro project.
Right-click Visual Basic for Applications in the list, and then click New
macro project.
You can also
Open (or “load”) a macro project
Do one of the following:
Rename a macro project
Right-click the project in the list, and then click Rename.
Copy a GMS-based macro project
Right-click the project in the list, click Copy to, and then choose the target location for the copied project.
NOTE: You cannot copy a document-based macro project. Such projects are stored within a document and cannot be managed separately from that document.
Display or hide all modules in the list
Click the Simple mode button
Add a module to a macro project
Edit a module in a macro project
Rename a module in a macro project
Right-click the module in the list, and then click Rename.
Delete a module from a macro project
Close (or “unload”) a GMS-based macro project
Right-click the macro project in the list, and then click Unload macro project.
NOTE: You can close a document-based macro project only by closing the document in which it is stored.
| To create a macro |
Click the desired container module, click New, and then click New macro.
Right-click the desired container module, and then click New macro.
You can also
Edit a macro
Delete a macro
| To record a macro |
1. |
Click Tools |
In the Macro Manager docker, click the project in which to store the macro, and
then click the Record button
The Record macro dialog box appears. |
2. |
In the Macro name box, type a name for the macro.
Macro names can contain numerals, but they must begin with a letter. Macro names cannot contain spaces or non-alphanumeric characters other than underscores ( _ ). |
3. |
Type a description of the macro in the Description box, and then click OK.
4. |
Perform the actions that you want to record.
The application begins recording your actions. If you want to pause recording, do one of the following: |
Click Tools |
Click the Pause recording button
5. |
To stop recording, do one of the following:
Click Tools |
Click the Stop recording button
You cannot record a macro if all available macro projects are locked.
Not all actions can be recorded — some because of their complexity (although
many such actions can be manually coded in the Macro Editor). When an
action cannot be recorded, a comment is placed in the macro code (“ The
recording of this command is not supported.”), but the recording
process continues until you stop it. You can view any comments in the code by
opening the macro in the Macro Editor.
You can specify the default macro project for recordings by right-clicking the
project in the Macro Manager docker, and then clicking Set as recording
project. However, you cannot specify a locked macro project.
You can cancel recording a macro, and discard any commands recorded thus
far, by clicking Tools |
You can also
Save the actions in the Undo list as a VBA macro
Click Tools
| To record a temporary macro |
1. |
Click Tools |
2. |
Click Tools |
3. |
Click Tools |
The macro is temporarily saved to the default recording project. When the current session is ended, the macro is deleted from that project. |
You cannot record a temporary macro if all available macro projects are locked.
Not all actions can be recorded.
You can specify the default recording project by right-clicking the project in
the Macro Manager docker, and then clicking Set as recording project. (You
cannot specify a locked macro project.) If you want, you can create multiple
temporary recordings by assigning each one to its own macro project.
| To play a macro |
Do any of the following:
Click Tools |
In the Macro Manager docker, double-click the macro in the list.
In the Macro Manager docker, click the macro in the list, and then click the
Run button
In the Macro Manager docker, right-click the macro in the list, and then click
Run.
| To play a temporary macro |
Click Tools |
This option is enabled only after you record a temporary macro.
If you have created multiple temporary macros, you must specify which macro
project contains the one that you want to run. Right-click the project in the
Macro Manager docker, and then click Set as recording project.
| To access the Macros Help file from within the Macro Editor |
1. |
While in Microsoft Visual Basic for Applications, press F2 to display the Object
Browser.
The Object Browser displays all the features and functions that can be automated in the Macro Editor. |
2. |
Choose Corel DESIGNER from the Library list box.
The Object Browser is updated to display only the features and functions of Corel DESIGNER that can be automated in the Macro Editor. Collectively, these features and functions are called an “object model.” |
3. |
Display the home page for the Macros Help file by pressing F1. You can browse
the object-model documentation for the application by accessing the “Object
Model Reference” section of the Help file.
Display the Help topic for a specific item in the Object Browser by clicking that
item and pressing F1.
You can also display a Help topic for any item in the Code window of the
Macro Editor by clicking that item and pressing F1.
