You can save a view of any part of a drawing. For example, you can save a view of an object at 230% magnification and then return to this specific view at any time.
If a document contains multiple pages, you can view them all at once by using the Page Sorter view. You can also display consecutive left-hand and right-hand pages on the screen at the same time (facing pages) and create objects that span two pages.
| To save a view |
1. |
Click Window |
2. |
Use the Zoom tools in the View manager docker to set up a view.
3. |
Click the Add current view button
You can also
Rename a view
Double-click a view name, and type a new name.
Delete a saved view
Click a view, and click the Delete current view button
If you disable the page icon
You can also save the current view by clicking the Zoom or Pan tool in the
toolbox, clicking in the Zoom levels list box on the standard toolbar, typing
a name, and pressing Enter.
| To switch to a saved view |
1. |
Click Window |
2. |
Click a view in the View manager docker.
You can also switch to a saved view by selecting it from the Zoom levels list
box on the standard toolbar.
| To view all pages in a multipage document |
Click View |
To return to the default page view, click the Page sorter view button on the property bar. |
| To view facing pages |
1. |
Click Layout |
2. |
In the Document list of categories, click Layout.
3. |
Enable the Facing pages check box.
4. |
Choose one of the following settings from the Start on list box:
Left side — starts the document on a left-hand page
Right side — starts the document on a right-hand page
You cannot view facing pages if the document uses a Tent Card or Top-fold
Card layout style, or if it contains multiple page orientations. The Left side
option is available only for the Full Page and Book layout styles.
When you enable the Facing pages check box, the content on the facing pages
is merged on one page. The layer structure for the merged page is based on the
left-hand page. The layers from the right-hand page are inserted above the
layers on the left-hand page. This rule also applies if you reorder the pages. If
you disable the Facing pages check box, the layers and content are
redistributed across separate pages. Objects that cross both pages are assigned
to a page according to where the center of the object is found.
It is recommended that you avoid switching back and forth between individual
pages and facing pages within the same document.
