Corel DESIGNER lets you place vector objects and bitmaps, such as photos, inside other objects, or containers. A frame can be any object, for example artistic text or a rectangle.When the object is larger than the frame, the object, called the contents, is cropped to fit the form of the frame. This creates a PowerClip object.
You can create more complex PowerClip objects by placing one PowerClip object inside another to produce a nested PowerClip object. You can also copy the contents of one PowerClip object to another.
You can create an empty PowerClip frame from an object, or convert a PowerClip frame back to an object. Creating empty PowerClip frames or text frames is useful when you want to define the layout of your document before adding the content. For more information about text frames, see Adding paragraph text. After you create an empty PowerClip frame, you can add contents to it. You can also add contents to a PowerClip frame that already contains another object.
After you create a PowerClip object, you can select or edit its contents, or reposition the contents inside the frame. Whenever a PowerClip object is selected, a floating toolbar appears.
The PowerClip toolbar lets you edit, select, extract, lock, or reposition the contents inside the frame. The toolbar appears whenever a PowerClip object is selected.
You can lock the PowerClip contents, so that when you move the frame, the content moves with it. If you want to delete the contents of a PowerClip object or modify it without affecting the frame, you can extract the contents.
You can set the default behavior for dragging content to PowerClip frames, centering new content, and marking empty PowerClip frames.
| 2 . |
Click Object PowerClip Place inside frame. |
You can also right-click an object or a group of objects, click PowerClip inside, and then click the object that you want to use as a frame.
If the content is placed so that it falls outside the frame in its current position, it is automatically centered inside the frame to make it visible. To change this setting, click Tools
Options, choose PowerClip frame in the Workspace list of categories, and set the options you want in the Auto-center new content area.
| 2 . |
Click Object PowerClip Create empty PowerClip frame. |
You can also right-click the object, choose Frame type, and click Create empty PowerClip frame.
You can also click the PowerClip frame button on the Layout toolbar. To open the Layout toolbar, click View
Toolbars
Layout.
You can also drag content to the PowerClip frame directly from Corel CONNECT, or from the Connect docker.
If the content is placed so that it falls outside the frame, it is automatically centered inside the frame to make it visible. To change this setting, click Tools
If the frame contains content, the content is deleted when the frame reverts to a regular object. To avoid losing the content, you can first extract it from the PowerClip object.
You can also convert a frame back to an object by clicking the No frame button on the Layout toolbar. To open the Layout toolbar, click View
Toolbars
Layout.
| 2 . |
Click the Select PowerClip contents button on the PowerClip toolbar. |
The Fit contents proportionally, Fill frame proportionally, and the Stretch contents to fill frame commands modify the PowerClip contents. The content remains modified even if you extract it from the frame.
You can also position the contents by clicking the Fit contents button on the PowerClip toolbar and clicking a command.
Examples of PowerClip contents positioned by using the following commands: Center contents (top left), Fit contents proportionally (top right), Fill frame proportionally (bottom left), and Stretch contents to fill frame (bottom right).
| 2 . |
Click Object Copy effect PowerClip from. |
| 2 . |
Click Object PowerClip Edit PowerClip. |
| 4 . |
Click Object PowerClip Finish editing this level. |
While you edit, the container is displayed in Wireframe mode and cannot be selected.
| 2 . |
Click Object PowerClip Lock contents to PowerClip. |
When the content is unlocked, it is separated from the frame, so that the frame can be moved independently. If you move the frame while the content is unlocked, the content remains stationary and is not visible until you move the frame over it.
You can also right-click a PowerClip object and click Lock contents to PowerClip, or you can select the PowerClip object and click the Lock contents to PowerClip button on the PowerClip toolbar.
| 2 . |
Click Object PowerClip Extract contents. |
You must extract the contents of each level in a nested PowerClip separately.
After the content is extracted, the frame remains as an empty PowerClip frame.
You can also right-click a PowerClip object and click Extract contents, or you can select the PowerClip object and click the Extract contents button on the PowerClip toolbar.
| 2 . |
In the Workspace category, click PowerClip frame. |
In the Drag content inside PowerClip area, choose PowerClip with content or Empty PowerClip from the list box, and then choose one of the following options:
In the Auto-center new content area, choose one of the following options:
Always — always centers new content |
Never — turns off auto-centering |
Enable the Show lines in empty PowerClip frames check box, and choose one of the following options:
Always — displays lines in empty PowerClip frames on screen and in printed or exported documents |
On screen only — displays lines in empty PowerClip frames only on screen |
