• | To manage fills and transparencies |
Corel DESIGNER lets you browse vector patterns, bitmap patterns, and fountain fills that are available on the Content Exchange or in your personal library. Any of these fills can also be used as transparency patterns. For more information, see Changing the transparency of objects.
The Content Exchange contains content provided by Corel or shared by users. To use the Content Exchange, you must sign in to your corel.com account. For more information, see Technical Suite memberships and Using the Content Exchange.
For more information about fills, see Filling objects.
1 . | Select an object. |
2 . | Click Edit Property manager. |
3 . | In the Property manager docker, click one of the following buttons in the Fill or Transparency section: |
• | Fountain fill |
• | Fountain transparency |
• | Vector pattern fill |
• | Vector pattern transparency |
• | Bitmap pattern fill |
• | Bitmap pattern transparency |
4 . | Open the Fill picker or the Transparency picker. |
5 . | Perform an action from the following table. |
In the Fill or Transparency picker, choose a category from the list, type a keyword in the Search box, and press Enter.
Open the list next to the Search box, and choose one of the following options:
Click a thumbnail, click the More options button , and click the Copy to personal button .
Click a thumbnail, and click the Share button .
Click a thumbnail, click the More options button , and click the Edit properties button .
Click a thumbnail, click the More options button , and click the Delete button .
Click a thumbnail, and click the Favorite button .
To remove a fill or pattern from your favorites, click the Unfavorite button .
Click a thumbnail, and click the Vote up or the Vote down button .
Click a thumbnail, click the More options button , and click the Flag button .
Click a thumbnail, click the More options button , and click the Hide button .
This procedure applies only to vector patterns, bitmap patterns, and fountain fills and transparencies.
You must sign in to your corel.com account to access content on the Content Exchange.
Fills and patterns in your personal library are saved in the My Documents\Corel\Corel Content\Fills folder.
