Objects created in Corel DESIGNER follow a path that gives them their defining shape. When this path is broken or cut, subpaths remain.
| • | Paths outline an object’s shape and are often visible as one or more line or curve segments. You can disconnect line segments from one another to create subpaths. Even though they are not connected, subpaths are still part of the defining path of the original object; however, you can extract a subpath to create two separate objects: the extracted subpath and the object it was extracted from. |
