| • | To smudge an object |
| • | To smear an object |
Smudging and smearing let you shape an object by pulling extensions or making indents along its outline. With smudging, the extensions and indents resemble streaks that vary little in width as you drag with the Smudge brush tool. With smearing, the extensions and indents have a more fluid shape that decreases in width as you drag with the Smear tool.
Smudging lets you distort an object by dragging its outline. When applying smudging to an object, you can control the extent and shape of the distortion, whether you use a pen tablet or a mouse.
You can apply the smudging effect to the inside and outside of an object.
| 1 . | Select a curve object using the Pick tool |
| 2 . | Click the Shape tools button in the toolbox, and click the Smudge brush tool |
| 3 . | Drag around the outline to distort it. |
Type a value in the Nib size box
Click the Pen pressure button
Type a value between -10 and 10 in the Dryout box
Type a value between 15 and 90 in the Tilt box
Click the Pen tilt button
Type a value between 0 and 359 in the Bearing box
Click the Pen bearing button
| 1 . | Select a curve object using Pick tool |
| 2 . | Click the Shape tools button in the toolbox, and click the Smear tool |
| 3 . | Do one of the following: |
| • | To smear the outside of an object, click outside an object, close to its edge, and drag outwards. |
| • | To smear the inside of an object, click inside an object, close to its edge, and drag inwards. |
Type a value in the Nib radius box on the property bar.
Type a value in the Pressure box.
Click the Smooth smear button
Click the Pointy smear button
