| • | To roughen an object |
The roughening effect lets you apply a jagged or spiked edge to objects, including lines, curves, and text. You can control the size, angle, direction, and number of the indentations, whether you use a pen tablet or a mouse.
You can also change the brush nib size.
Roughening allows you to apply jags or spikes to part of an outline or path.
| 1 . | Select a curve object using the Pick tool |
| 2 . | Click the Shape tools button in the toolbox, and click the Roughen brush tool |
| 3 . | Point to the area on the outline that you want to roughen, and drag the outline to distort it. |
Type a value between 0.01 and 2.0 in the Nib size box
Type a value between 1 and 10 in the Frequency of spikes box
Click the Pen pressure button
Type a value between 0 and 90 in the Tilt box
Type a value between -10 and 10 in the Dryout box
Click the Pen tilt button
Choose Fixed direction from the Spike direction list box. Type a value between 0 and 359 in the Pen bearing box
Choose Stylus setting from the Spike direction list box on the property bar.
Choose Auto from the Spike direction list box on the property bar.
Objects with distortions, envelopes, and perspective applied to them are converted to curve objects before the roughening effect is applied.
To make the tilt angle and bearing responsive to the stylus, right-click the roughened object with the Roughen brush tool, and select a command from the context menu.
