| • | To add or delete a node |
| • | To reduce the number of nodes in a curve object |
| • | To join the end nodes of a single subpath |
| • | To join the nodes of multiple subpaths |
In the toolbox, click the Shape tool
In the toolbox, click the Shape tool, select a curve object, and double-click a node.
| 1 . | In the toolbox, click the Shape tool |
| 2 . | Click a curve object, and do one of the following: |
| • | To reduce the number of nodes in the entire object, click the Select all nodes button |
| • | To reduce the number of nodes in a part of a curve object, marquee select the part you want to change. |
| 3 . | Do one of the following: |
| • | Click Reduce nodes on the property bar to have overlapping and redundant nodes automatically removed. |
| • | Move the Curve smoothness slider to control the number of nodes that are removed. Removing many nodes can reshape the curve object. |
| 2 . | Click a subpath. |
| 3 . | Click the Close curve button |
You can close multiple subpaths in an object by clicking Object
Join curves and choosing settings in the Join curves docker. For more information, see Joining curves.
| 2 . | Hold down Shift, and click a node from each subpath. |
| 3 . | Click the Extend curve to close button |
If you want to join nodes from separate curve objects, you must first combine them into a single curve object, and then join the end nodes of the new subpaths. For information about combining objects, see Combining objects.
