Corel DESIGNER lets you apply a variety of preset brushstrokes, ranging from brushstrokes with arrowheads to brushstrokes that are filled with patterns. When you draw a preset brushstroke, you can specify some of its attributes. For example, you can change the width of a brushstroke and specify its smoothness.
You can also create custom brushstrokes by using an object or a group of vector objects. When you create a custom brushstroke, you can save it as a preset.
If you have access to a brushstroke that is not listed in the Brushstroke list box, you can apply it by clicking the Browse button on the property bar, and locating the brushstroke file.
| 4 . |
Click the Save linear pattern stroke button on the property bar. |
Example of a custom linear pattern brushstroke
You can also create custom brushstrokes by clicking Window
Linear patterns and specifying the settings that you want in the Linear patterns docker.
