Corel DESIGNER lets you add lines and brushstrokes by using a variety of techniques and tools. After you draw lines or apply brushstrokes to lines, you can format them. You can also format the outlines that surround objects.
The program provides you with preset objects that you can spray along a line.
You can also create connector lines, dimension lines, and callouts in drawings.
This section contains the following topics:
| • | Setting the default property values |
| • | Drawing lines |
| • | Parallel drawing |
| • | Closing multiple line segments |
| • | Drawing callouts |
| • | Drawing connector lines |
| • | Drawing dimension lines |
| • | Formatting lines and outlines |
| • | Adding arrowheads to lines and curves |
| • | Drawing calligraphic and preset lines |
| • | Sketching naturally with intelligent stroke adjustment |
| • | Applying linear-pattern brushstrokes |
| • | Applying brushstrokes that respond to pen pressure, tilt, and bearing |
| • | Spraying linear patterns along a line |
| • | Using pressure-sensitive pens and devices |
| • | Support for Real-Time Stylus (RTS) pen tablets and devices |
