To create a symmetry group, you can convert an existing object to a symmetry group, or you can start from scratch by drawing objects in symmetry mode. The objects that you convert or draw are known as primary objects; the objects generated by the symmetry are known as object copies.
Corel DESIGNER offers mirror symmetry, which lets you create identical shapes and curves that are mirrored or reflected on a set of planes. In the default mirror symmetry mode, primary objects are reflected along a single symmetry line. If you want to create a more complex design, you can add more symmetry lines.
Single-line symmetry (left); multi-line symmetry (right)
When creating a symmetry group from scratch, you can start by setting up the planes of symmetry. You can add more symmetry lines to create more object copies. In addition, you can reposition and rotate the symmetry lines by dragging them in the drawing window or by specifying values on the property bar. Each symmetry group has a center of symmetry, which is shown by a circular cursor when the symmetry lines are selected. With multi-line symmetry, the intersection point of the symmetry lines is the center of symmetry. Symmetry lines are rotated about the center of symmetry. You can move the center of symmetry by dragging it, or you can specify its exact location by using x and y coordinates.
From left to right: Default symmetry line, adding a symmetry line, rotating the symmetry lines.
For information about how to edit symmetry groups, see Editing symmetry groups.
| 2 . |
Click Object Symmetry Create New Symmetry. |
| 3 . |
Click Object Symmetry Finish Editing Symmetry. |
To accurately mirror an object that has a calligraphic outline, you must first link the outline thickness to the object’s size. To do this, select the object, double-click the Outline icon
in the lower-right corner of the application window, and in the Outline Pen dialog box, enable the Scale with object check box.
You can also create a symmetry group from an object by right-clicking the object and clicking Create New Symmetry.
You can create a symmetry group from multiple shapes and curves.
| 1 . |
| 1 . |
Using the Pick tool  , drag the symmetry line in the drawing window.
Using the Pick tool  , click the symmetry line twice, and drag a rotation handle.
