The Project Timer (View
Toolbars
Project Timer) lets you track the time spent on a project with ease. To fine-tune the tracking records, you can add tasks and track the time spent on each task. You can give a task a meaningful name, and you can edit a task log by resetting the counter or specifying the task duration and start and finish date.
The Project Timer toolbar appears next to the standard toolbar.
| To track time spent on a project |
| 1 . | Open or start the project that you want to track. |
| 2 . | Click the Track/Pause/Off button |
| If the Project Timer toolbar is not displayed, click View |
| 3 . | Start working on the project. |
| The Track/Pause/Off button on the toolbar shows you if a task is being tracked. This button has the following states: |
| To add, activate, delete, modify, or move a task |
| • | Click the drop-down arrow on the Project Timer toolbar, and in the Project Timer panel, perform any of the tasks from the following table. When you are finished, click outside the Project Timer panel to hide it. |
Click New.
The task list shows the task as Active to indicate that this is now the task that you are tracking.
Select the task, and click Delete.
Click the Recorded time field twice, and specify the amount of time you want.
Notes: From the task list, you can modify only the duration of a task that is not active (not being tracked). To modify the active task, you must use the Edit Active Task dialog box. For more information, see To edit the active task.
Click twice the Dates field of the task, and specify the start and finish time and dates you want.
| To edit the active task |
| 1 . | Click the drop-down arrow on the Project Timer toolbar. |
| 2 . | Click Edit, and perform a task from the following table. |
Click Reset counter.
Click Edit task, and do any of the following:
The recorded time for task duration is not linked to the start and finish time and dates. Changing the value in the Recorded time box does not update the Start and Finish boxes, and vice versa.
| To create a time sheet report |
| 2 . | Click the Export options button , and click one of the following commands: |
| • | Export to CSV — to save the time sheet as a CSV file. CSV files preserve the information in a table-structured format similar to spreadsheets. Unlike spreadsheets, they can contain only one sheet and do not support formatting options and formulas. The CSV files exported from Project Timer use commas as field separators. |
| • | Export to TXT (Comma separated) — to save the time sheet as a TXT file that uses commas as field separators |
| 3 . | In the Save As dialog box, locate the folder where you want to save the file, and type a filename. |
| 4 . | Open and format the file in a spreadsheet application. |
| To adjust Project Timer settings |
With the help of the Project Timer Settings dialog box, you can set Project Timer to start or pause tracking automatically in response to specific actions or changes. In addition, inactivity settings help you decide how to treat periods of time when the project is open but there are no recorded document changes. For example, you can set Project Timer to display a prompt or pause tracking after a specified time of inactivity. You can also customize the Project Timer toolbar by displaying and hiding controls.
| 1 . | Click the drop-down arrow on the Project Timer toolbar to show the Project Timer panel. |
| 2 . | Click the Project Timer options button , and click Settings. The Project Timer Settings dialog box appears. |
| 3 . | In the Project Timer Settings dialog box, perform a task from the following table. |
In the Automation area, enable any of the following check boxes below Start recording when:
In the Inactivity detection area, choose one of the following options from the On inactivity list box:
In the Inactivity tolerance box, type a value.
Enable any of the following check boxes below Pause recording when:
Enable or disable any of the following check boxes in the Toolbar appearance area:
| To respond to the Inactivity prompt |
| • | In the Inactivity Detected dialog box, click one of the following buttons: |
| • | Discard — to delete the entire period of inactivity from the tracking record |
| • | Track as work — to record the period of inactivity as work time. This option is useful to track time spent on tasks related to the project but not performed in Corel DESIGNER. For example, you may have done research on the project or discussed it at length with a client over the phone. Hence, you want to track this time even though you did not make any changes to the project itself. |
| • | Custom — to log a custom amount of time. In the Custom Activity Log dialog box, specify the amount of time (in minutes) that you want to be tracked as work. For example, you may have been away from your desk for an hour. If you worked for 20 minutes during that hour on project-related tasks, you can choose to log only 20 minutes. The remaining 40 minutes will be discarded. |
| If you want Project Timer to remember your choice and apply it all future inactivity, enable the Remember and don’t ask again check box before clicking a button in the dialog box. This action suppresses all inactivity prompts. To start displaying prompts again, you must change the inactivity preferences in the Project Timer Settings dialog box. In the Inactivity detection area, choose Prompt from the On inactivity list box. |
The Custom Activity Log dialog box
