Undo and redo
Corel PHOTO-PAINT lets you undo actions you apply to an image, starting with the most recent action. If you don’t like the result of undoing actions, you can redo them. You can undo or redo actions applied to an image, such as a brushstroke, an effect, or a transformation; however, you cannot undo or redo actions applied to the workspace, such as changing preferences.
The undo settings can be customized, allowing you to increase or decrease the number of actions you can undo and redo.
Keep in mind that the higher the number of actions in the undo list, the more memory is required to maintain the undo list. You can free memory by permanently clearing all actions from the undo list.
You can also restore parts of an image by erasing the last action. For more information, see Erase image areas.
Left to right: Original image; cropped image; undoing the cropping action restores the dimensions of the image.
To undo or redo actions
Back to Top
To
Do the following
Undo the last action
Click Edit Undo [last action].
Redo the last action
Click Edit Redo [last action].
Undo or redo a series of actions
In the History docker, choose an action from the list. All actions listed below the action you choose will be undone. If the History docker is not open, click Window Dockers History.
Remove all actions in the History docker to free memory
Click Edit Purge Undo List.
When you undo a series of actions, the action you choose and all actions listed below it are undone.
When you redo a series of actions, the action you choose and all actions listed between it and the last undone action are redone.
To customize undo settings
Back to Top
1 Click Tools Options Corel PHOTO-PAINT.
2 Click General.
3 In the Memory area, type a value in the Undo levels box.
You can specify up to 99 undo levels; however, the number of undo levels affects the size of the swap disk. Reduce the number of undo levels if you find that your computer is not operating at the speed you want.
