You can add text to enhance images. When you add text, you can specify its font, size, and alignment, as well as the character spacing and line spacing.
Text is created as an object by default; therefore, you can move, size, scale, rotate, flip, skew, distort, and apply perspective; however, you will lose distortion or perspective effects if you add, remove, or edit text characters. For more information about working with objects, see Working with objects. Text can also be rendered as an editable area of a mask. For more information about creating editable areas, see Working with masks.
After you add text, you can edit the text by changing its color, painting it, or filling it with patterns and textures.
| To add text |
1 |
Click the Text tool |
2 |
Choose a font from the Font list box on the property bar.
3 |
Choose a font size from the Font size list box on the property bar.
4 |
Click in the image window, and type the text.
You can also
Align multiple lines of text
On the property bar, open the Text alignment picker, and click a setting. Text is aligned with the bounding box.
Adjust character spacing
On the property bar, type a value in the Character and line spacing box.
Adjust line spacing
You render the text as an editable area by selecting the text with the Text tool
Text is created with the Text tool.
| To change the color of text |
1 |
2 |
Point to the text until the pointer becomes a cursor.
3 |
Select the text.
4 |
In the color control area, double-click the Foreground color swatch |
| To paint text |
1 |
In the toolbox, click the Object pick tool |
2 |
Select the text.
3 |
Enable the Lock transparency button |
If the Objects docker is not open, click Window |
4 |
In the toolbox, click the Paint tool |
5 |
Specify any tool settings on the property bar.
6 |
7 |
Drag across the text.
Ensure that text is correct before you paint. After painting, the paint effects are
lost if you add, remove, or edit text characters.
| To fill text |
1 |
2 |
Select the text.
3 |
In the toolbox, click the Fill tool |
4 |
5 |
Click each text character that you want to fill.
You must click directly in a character; otherwise, the fill is applied to the entire image. You can undo an unwanted fill by clicking Edit |
Ensure that text is correct before filling. After filling, the fill effects are lost if
You can quickly zoom into a text character by clicking the Zoom tool |
You can render the text as an editable area by selecting the text object with the
Text tool |
You can paint text or fill it with patterns and textures.
