Adding drop shadows to objects
There are three types of drop shadows: glow, flat, and perspective. Glow drop shadows silhouette objects and are centered horizontally and vertically; they simulate a light source shining straight onto an object. Flat drop shadows simulate the effect of directional light, so shadows are offset. Perspective drop shadows create three-dimensional depth. You can add a drop shadow to any object, including text.
The object on the left has a flat drop shadow, while the object on the right has a perspective drop shadow.
You can create and adjust drop shadows in the image window. You can also change the color, position, direction, and transparency of a drop shadow directly in the image window.
You can also apply preset drop shadows. When you apply a preset, you can modify it to create a custom drop shadow. For example, you can change its direction and distance from an object, its color, and its opacity. By default, the edges of drop shadows feature squared feathering. You can choose another feathering type, such as a Gaussian blur which creates a realistic-looking drop shadow. You can also copy a custom drop shadow or save it as a preset.
When you change the shape or transparency of an object that has a drop shadow, the drop shadow automatically also changes.
You can remove a drop shadow at any time.
To add a drop shadow Back to Top
In the toolbox, click the Drop shadow tool .
Select an object.
If you want to create a flat drop shadow, drag from the center of the object.
If you want to create a perspective drop shadow, drag from the edge of an object.
You can also
Change the color of the drop shadow
Drag a color swatch from the color palette to the end node on the drop shadow arrow.
Move the drop shadow
Drag the end node on the drop shadow arrow.
Flip a flat drop shadow from the center of the object or a perspective drop shadow to the edge of the object.
Drag the start node on the drop shadow arrow.
Change the direction of or offset the drop shadow
Drag the drop shadow arrow head.
Adjust the drop shadow’s opacity
Drag the triangular Transparency handle on the drop shadow arrow.
Adjust the edge feathering
Drag the triangular Feather handle on the drop shadow arrow. By default, squared feathering is used, but you can choose another type from the Feather edge picker on the property bar. For example, the Gaussian blur creates a realistic drop shadow.
To add a glow drop shadow Back to Top
Select an object.
On the property bar, choose one of the following presets from the Preset list box:
Large glow
Medium glow
Small glow
You can also
To add a preset or custom drop shadow Back to Top
Select an object.
Choose a preset from the Preset list box on the property bar.
If you modify the preset by changing any of the values on property bar, the preset name changes to Custom in the Preset list box.
4
Open the Shadow color picker on the property bar, and click a color.
5
On the property bar, type values in any of the following boxes:
Shadow direction — lets you specify the angle of the shadow in relation to the object
Shadow offset — lets you specify the distance of the shadow from the object’s point of origin
Shadow fade — lets you specify the percentage by which a perspective drop shadow fades as it moves away from the object
Shadow stretch — lets you specify the length of a perspective shadow
Shadow transparency — lets you specify the transparency of the shadow
Shadow feathering — lets you specify the number of pixels on the edge of the shadow that are feathered to create a soft edge. By default, squared feathering is used, but you can choose another type from the Feather edge picker on the property bar. For example, if you want to create a realistic drop shadow, choose the Gaussian blur. You can also specify a direction for the feathered pixels from the Feathering direction picker .
You can also
Save a custom drop shadow as a preset
Click the Add preset button on the property bar, and type a name for the drop shadow in the Save preset as box.
Specify the offset and the feather width of the offset as a percentage of the size of the drop shadow
In the Save as preset dialog box, enable the Shadow relative check box.
After you choose a preset, you can modify many drop shadow attributes by adjusting the nodes and triangle handles on the drop shadow arrow.
To copy a drop shadow Back to Top
Select the object to which you want to apply a drop shadow.
Click the Copy shadow properties button on the property bar.
4
Click the object that has the drop shadow properties you want to copy.
To remove a drop shadow Back to Top
Select an object with a drop shadow.
Press Delete.
You can also remove a drop shadow by choosing None from the Preset list box on the property bar.
