Anti-aliasing text
You can use anti-aliasing to smooth the appearance of text. Anti-aliasing can improve the legibility of on-screen text, especially text that uses a small font size. When adding text to an image, anti-aliasing is applied by default. You can, however, remove text anti-aliasing.
To apply anti-aliasing to text Back to Top
Select the text by using the Text tool .
Choose one of the following options from the Text antialiasing list box on the property bar:
Soft — produces text that is softer in appearance, but remains true to the font shape
Hard — produces text that is very clear and sharp
To remove anti-aliasing from text Back to Top
Choose None from the Text antialiasing list box on the property bar.
