You can control the transparency level, and the pattern of the transparency, when you apply a fill to an entire image. The fill can be applied to any object layer to create foreground or background effects.
| To apply a transparency pattern to a fill |
1 |
Click Edit |
2 |
In the Edit fill & transparency dialog box, click the Fill color tab.
3 |
Enable one of the following options:
Foreground color
Background color
Current fill
4 |
Click a Fill type button.
5 |
Click Edit, and modify any settings in the corresponding dialog box.
6 |
Click the Transparency tab.
7 |
Choose a pattern type from the Type list box.
8 |
Type values in any of the following boxes:
Start transparency
End transparency
9 |
Drag in the display window at the top of the dialog box to place the adjustment
nodes and preview the fill.
