When you choose color profiles, colors are matched between devices as closely as possible by the color management module (CMM) of the Microsoft Image Color Management (ICM), which is the default CMM. Color management modules are also known as “color engines.”
On Windows Vista, you can also use the Windows Color System (WCS) color management module. In addition, you can use the Adobe CMM if it is installed on your computer. To download and install the Adobe CMM, visit the Adobe Web site.
You can preserve pure black color in the destination color space during color conversion. For example, if you are converting an RGB document to a CMYK color space, pure RGB black (R=0, G=0, B=0) can be mapped to pure black CMYK colors (K=100). This option is recommended for grayscale documents or documents that contain mostly text. Note that preserving pure black during color conversion may create solid edges of black in effects and gradient fills that contain black.
By default, grayscale colors are converted to the CMYK black (K) channel. This process ensures that all grayscale colors print as shades of black, and no cyan, magenta, and yellow inks are wasted during printing.
| To choose color-conversion settings |
1 |
Click Tools |
2 |
In the Color conversion settings area, choose a color engine from the Color
engine list box.
