Corel Application Recovery Manager (C.A.R.M.) is an online wizard that allows you to save your work and exit in case the application becomes unstable. You can also send an online report to Corel that documents the nature of the problem and the events that led to it. Note that C.A.R.M. can be used only in Windows XP.
The C.A.R.M. wizard opens automatically at program failure and then offers three courses of action:
saving the drawing and closing the application
exiting the application without saving the drawing
continue working
With the last option, there is no guarantee that you can recover any work in your drawing after the last time you saved or kept the program open.
After you have made your selection, you can report the details of the problem to Corel with an attached program log. Your report will be vital part of Corel's product improvement efforts.
You can disable C.A.R.M., but doing so can result in your losing any work since the last time you saved.
| To disable Corel Application Recovery Manager |
1 |
Click Tools |
2 |
In the list of categories, click Global.
3 |
Disable the Enable CARM check box.
All Corel applications installed on your computer are affected when C.A.R.M.
is disabled.
