You can create a custom brush by modifying brush attributes. Once you have created a custom brush, you can save it and use it again.
The shape of a brush is determined by the brush nib. The preset nib shapes can be modified or a nib can be created from an editable area and saved. The nib attributes you can adjust are
Transparency — lets you specify the transparency level for the nib
Rotate — lets you specify the angle at which the nib is rotated
Flatten — lets you specify the amount by which the nib is flattened along one
dimension
Soft Edge — lets you specify the transparency and width of the edges of the nib
The stroke attributes you can modify are
Smoothing — lets you specify a value for the smoothing of the stroke when the
mouse moves fast. A higher value results in a rounder curve.
Fade out — lets you specify the intensity of the fade-out effect for the brushstroke.
A higher value results in a shorter brushstroke, i.e., the brushstroke runs out of
paint faster. A negative value results in a fade-in effect.
The dab attributes you can adjust are
Number of dabs — lets you specify the number of dabs in a brushstroke
Spacing — lets you specify the amount of space between dabs along the length of
the brushstroke. A value of 1 produces a solid line. A higher value separates the
dabs in the brushstroke.
Spread — lets you specify the distance between dabs along the width of the
brushstroke. A higher value results in a thicker brushstroke.
Hue — lets you specify the hue variation in the brushstroke
Saturation — lets you specify the saturation variation in the brushstroke
Lightness — lets you specify the lightness variation in the brushstroke
Loading a preset brush texture gives you additional design options. The texture attributes you can adjust are
Brush Texture — lets you specify how much of the texture is applied to the
brushstroke
Edge texture — lets you specify how much of the texture is applied to the edges of
the brushstroke. The Edge Texture box is available only if the nib has a soft edge.
Bleed — lets you specify the extent to which brushstrokes become diluted
throughout the stroke. If a Sustain Color value is specified, traces of the paint
remain throughout the brushstroke.
Sustain color — lets you specify the extent to which traces of the paint color
appear in a brushstroke with a specified bleed value
The color attributes you can modify are
Hue range — lets you specify the amount of hue variation in the brushstroke
Hue speed — lets you specify how fast the hue value changes
Saturation range — lets you specify the amount of saturation variation in the
brushstroke
Saturation speed — lets you specify how fast the saturation value changes
Lightness range — lets you specify the amount of lightness variation in the
brushstroke
Lightness speed — lets you specify how fast the lightness value changes
| To create a custom brush |
1 |
In the toolbox, click the Paint tool |
2 |
On the property bar, open the Brush category picker, and click a tool.
3 |
Choose a preset brush in the Brush type list box on the property bar.
4 |
In the Brush settings docker, move the Size slider.
If the Brush settings docker is not open, click Window |
5 |
In the Brush settings docker, click the roll-down arrow on any of the following
bars, and specify values for any attributes:
Nib properties
Stroke attributes
Dab attributes
Brush texture
Color variation
| To create a brush nib from an editable area |
1 |
Define an editable area.
2 |
3 |
4 |
In the Brush settings docker, click the Nib options button |
5 |
Click Create from contents of a mask.
6 |
Type a value in the Nib size box.
| To load a preset brush texture |
1 |
2 |
3 |
In the Brush settings docker, click the Load texture button |
4 |
Choose the folder where the texture file is stored.
5 |
Double-click the filename.
6 |
In the Brush settings docker, click the roll-down arrow on the Brush texture bar,
and type a value from 0 to 100 in any of the following boxes:
Brush texture — lets you adjust the amount of texture applied to a brushstroke
Edge texture — lets you adjust the amount of texture applied to the edge of a
brushstroke
