Formatting text
Corel PHOTO-PAINT lets you format text to enhance its appearance. For example, you can change the font attributes, such as style and size, and you can underline, strike through, and overline text. You can also add superscript or subscript text, which is useful if an image requires footnotes or mathematical symbols.
Kerning text changes the space between characters. You can also shift text characters vertically and horizontally or change the angle of the text.
To change font attributes Back to Top
Select the text by using the Text tool .
Click Object Text Character formatting.
In the Character formatting docker, modify any font attributes.
You can also change the font style of selected text by clicking the Bold button or the Italicize button on the property bar.
To underline, strike through, and overline text Back to Top
In the Character formatting docker, click the roll-down arrow on the Character effects bar, and choose a line style from one of the following list boxes:
Underline — underlines the text
Strikethru — adds a line through the text
Overline — adds a line above the text
You can also
Customize the thickness of a line
In the Underline, Strikethru, or Overline list box, click Edit, and type a value in the Thickness box.
Customize the distance between the text and the line
In the Underline, Strikethru, or Overline list box, click Edit, and type a value in the Baseline shift box.
You can add a single underline to selected text by clicking the Underline button on the property bar.
To add superscript or subscript text Back to Top
In the Character formatting docker, click the roll-down arrow on the Character effects bar, and choose one of the following text positions from the Position list box:
Superscript
Subscript
To kern text Back to Top
In the Character formatting docker, type a value in the Range kerning box.
To shift characters Back to Top
In the Character formatting docker, click the roll-down arrow on the Character shift bar, and type a value in any of the following boxes:
Horizontal shift — shifts text characters to the left or right
Vertical shift — shifts text characters up or down
Positive horizontal values move the characters to the right; negative horizontal values move them to the left. Positive vertical values move the characters up; negative vertical values move the characters down.
To change the angle of text Back to Top
In the Character formatting docker, click the roll-down arrow on the Character shift bar, and type a value from 0 to 360 in the Angle box.
