You can use screen dithering to improve the display quality of images if you are using a monitor that displays fewer than 16-million colors (24-bit color). Screen dithering places pixels with specific color values relative to other pixels. The relationship of one colored pixel to another creates the appearance of additional colors that do not exist in the color palette.
| To improve the display quality of an image |
Click View |
None — disables dithering when your computer is in 16-bit color mode
Error diffusion — spreads the dithering across a wider area and tailors the
dithering pattern to the transition being simulated
Ordered — approximates color blends using fixed dot patterns. This dithering
type applies more quickly than Error diffusion but is less accurate.
