Corel PHOTO-PAINT gives you tools to create symmetrical and orbital patterns.
You can paint symmetrical patterns on an image by using the radial or mirror brush symmetry mode. When you paint in radial mode, satellite brush nibs, called satellite points, create brushstrokes around a center point. When you paint in mirror mode, an identical brushstroke is created on the horizontal plane, the vertical plane, or both.
You can create spiral effects by painting an image with orbits. Orbits are circular paths that rotate around a center point. Orbits let you paint spirals, pods, and rings. For example, you can draw a single spiral and adjust the size and closeness of the coils. You can also vary the size of the coils to create rounded segments called pods, or increase the number of orbits to create rings.
| To paint symmetrical patterns |
1 |
In the toolbox, click the Paint tool |
2 |
On the property bar, open the Brush tool picker, and click a tool.
3 |
Click Window |
4 |
On the Symmetry bar, click one of the following buttons:
Radial symmetry |
Mirror symmetry |
5 |
Click the Set symmetry center button |
6 |
Drag in the image window.
Click the No symmetry button |
| To paint with orbits |
1 |
2 |
3 |
Click the Orbits button |
4 |
Click the Orbits bar in the Brush settings docker.
If the Brush settings docker is not open, click Window |
5 |
Type a value in any of the following boxes:
Number of orbits — lets you specify the number of orbits that are distributed
around the center of a brushstroke. Use a value from 1 to 128. Use lower values
for spirals and higher values for rings.
Radius — lets you specify the distance between the center of a brushstroke and
the orbits. Use a value from 1 to 999. A smaller nib requires higher values.
Rotation speed — lets you specify the speed at which the orbits rotate around a
brushstroke. Use a value from 0 to 100. Higher values result in closer coils.
Grow speed — lets you specify the speed at which the orbits move toward the
center of a brushstroke. Use a value from 0 to 100. Higher values increase the
frequency of the size variation.
Grow amount — lets you specify the distance that the orbits move when
rotating toward the center of a brushstroke. Use a value from 0 to 100. Higher
values increase the size variation and create pods.
6 |
You can hide or display the point around which the orbits rotate clicking the
Include center button |
