Repeating brushstrokes
You can save a brushstroke and then reapply it to the same image or other images. You can also repeat a brushstroke along the border of a path or mask. For information about applying a brushstroke to a path, see Applying brushstrokes to paths.
You can edit a saved brushstroke to create new effects by adjusting attributes such as the size, number, angle, and color of the brushstroke.
To save a brushstroke Back to Top
In the toolbox, click the Paint tool .
On the property bar, open the Brush category picker, and click a tool.
Choose a brushstroke from the Brush type list box.
4
Click Edit Repeat brushstroke.
5
In the Repeat stroke dialog box, click the Stroke flyout arrow, and click Add last tool stroke.
6
Choose the folder where you want to save the brushstroke.
7
Type a filename in the Filename box.
To apply a saved brushstroke Back to Top
If there are two menu items called Repeat brushstroke, click the second one.
4
Choose a brushstroke from the Stroke list box.
5
Click in the image window to apply the brushstroke.
If you want to apply more than one brushstroke, continue clicking.
To edit a saved brushstroke Back to Top
4
In the Repeat stroke dialog box, choose a saved brushstroke from the Stroke list box.
5
In the Repeat stroke dialog box, modify any attributes.
6
