Sharpening and reducing noise in RAW camera files
You can sharpen RAW camera files to enhance image edges.
RAW camera files may contain luminous (grayscale) and color (chroma) noise that is especially obvious in the darker areas of an image. Luminous noise appears as a “white snow” effect; color noise appears as random pixels of different colors scattered against image areas. You can reduce noise in RAW camera files to improve image quality.
Before (left) and after (right) the amount of noise is reduced in a RAW camera image
To sharpen a RAW camera file Back to Top
Do one of the following:
Click File Open.
Click File Import.
Select a RAW camera file or multiple RAW camera files, and click Open or Import.
In the Camera RAW Lab, click the Detail tab.
4
Move the Sharpness slider to enhance the edges in an image.
To reduce noise in a RAW camera file Back to Top
Click File Open.
Click File Import.
Click the Detail tab.
4
Move any of the following sliders to the right:
Luminance noise — to reduce the amount of luminance noise
Color noise — to reduce the amount of color noise. Note that higher settings may decrease the color accuracy of an image.
Adjusting both the Luminance noise and Color noise settings produces better results.
