Undoing and redoing actions
Corel PHOTO-PAINT lets you undo actions you apply to an image, starting with the most recent action. If you don’t like the result of undoing actions, you can redo them. You can undo or redo actions applied to an image, such as a brushstroke, an effect, or a transformation; however, you cannot undo or redo actions applied to the workspace, such as changing preferences.
The undo settings can be customized, allowing you to increase or decrease the number of actions you can undo and redo.
Keep in mind that the higher the number of actions in the undo list, the more memory is required to maintain the undo list. You can free memory by permanently clearing all actions from the undo list.
You can also restore parts of an image by erasing the last action. For more information, see Erasing image areas.
Left to right: Original image; cropped image; undoing the cropping action restores the dimensions of the image.
To undo or redo actions Back to Top
To
Do the following
Undo the last action
Click Edit Undo [last action].
Redo the last action
Click Edit Redo [last action].
Undo or redo a series of actions
In the Undo docker, choose an action from the list. All actions listed below the action you choose will be undone. If the Undo docker is not open, click Window Dockers Undo.
Remove all actions in the Undo docker to free memory
Click Edit Purge Undo list.
When you undo a series of actions, the action you choose and all actions listed below it are undone.
When you redo a series of actions, the action you choose and all actions listed between it and the last undone action are redone.
To customize undo settings Back to Top
Click Tools Options.
In the Workspace list of categories, click Memory.
Type a value in the Undo levels box.
You can specify up to 99 undo levels; however, the number of undo levels affects the size of the swap disk. Reduce the number of undo levels if you find that your computer is not operating at the speed you want.
If you disable the Enable undo list check box, you will be able to undo only the number of levels specified in the Undo levels box. With the check box enabled, you can undo all changes you made to the image from the Undo docker, regardless of how many undo levels you’ve specified. Note that the number of undo levels will still be limited if you are using menu commands, and not the Undo docker, to undo your actions.
